2001 Infiniti QX4 Window switches will these fit?
Ryman
Car: 2001 Infiniti QX4
I'm just wondering if these will fit the factory harness so I can do the led mod to them. http://cgi.ebay.com/ebaymotors...ories
I tried to do some research but I didn't really know where to start with the research I just googled and it wasn't very helpful any help would be greatly appreciated thanks
Pwnin O'Brien
Which switch pack did you break, driver or passenger? Also what color is your interior and does it have wood grain? You technically only need to replace the internals (the black plastic box, not the entire piece of trim) so the third option is probably what you're looking for, if it is the passenger side you need to replace.
Ryman
Yeah I just messed up the internal things so I was just going to take the internals and put it into my current armrest. I actually messed up both I did the same thing to both sides lol. Why do I need to replace the whole thing if it's the passenger side? and I guess the real question was are the internals going to match like the harness go into the black box?
Pwnin O'Brien
Yeah, since the eBay auction says it works with 2001 then it should be plug-n-play and you can just swap the black boxes. Just make sure you're more careful with the new ones!
Ryman
lol yeah i'll order them and take them apart and post some pics for help thanks pwnin BIG HELP
Pwnin O'Brien
Also, let me note that you should double check the buttons to make sure they match the other side (make sure the passenger side buttons match the driver side buttons and vice versa). If you look at the pictures in the switch pack LED thread you can see that Rogers window button looks different from mine (my buttons don't spell out the word AUTO as well as the little light windows on the switches are different sizes). I say this because the one auction says the switch pack is compatible with 2001 2002 2003 2004 and I know for sure they aren't all the same (as evidenced by the images in the switch pack LED thread).
