joshbowling »
https://forums.nicoclub.com/joshbowling-u253674.html
Thu Jul 09, 2015 7:47 am
Hi All,
I've been troubleshooting a headlight issue. I ruled out ballast, bulb by replacing. I've ruled out switch, wiring by pulling both headlights off and swapping sides.
From these tests, I've deduced that it must be something in the assembly itself. Does this seem correct so far?
If so, I'm wondering if I should dig into the headlight assembly or buy another off ebay, then sell the ballast from the broken headlight assembly. And, perhaps sell the broken assembly as-is.
If any of you have any advice, I'd very much appreciate it.
Thanks again,
Josh
