We supply the factory service manual (The manual Nissan techs use to repair your vehicle) for free via a downloadable PDF. The following link will take you to all of the necessary manuals (each part of the car is broken up into separate manuals, start at 'Quick Reference Index.pdf' to see which PDF you need; for the MAF sensor you need to look in 'Engine Control System.pdf'). I suggest downloading them all to your computer so you have them readily available and you can print out individual pages as you need them.brit152 wrote:Thank you so much...I've ordered a service manual on line and waiting for that to arrive since I have no idea what the MAF looks like or where it is under the hood.Once I do get it and have had a chance to read, I'll be in touch via MSN for some additional help...I can't thank you enough
does it do it when the engine is cold, like when u first start driving for the day or a good time after u have been driving the car like a hour or so?brit152 wrote:I have a 2001 Infiniti QX4 6cyl 3.5L 4x4. It stalls out when I'm at a stop light or within minutes of coming to a stop. No shudders or surges and no check engine lights. The dealership want to replace the MAF for $600 but after doing a little research on line it seems I should try some other things myself first. Now I'm just a girl with no mechanical experience but have changed the HiD bulbs on the headlights, can change tires and oil...I am ready to try anything other than shell out money I can't afford right now, so I could really use some advice on what to try and how.
Mine stalls out after the engine gets warm. Replaced the coils and plugs because I was having a misfire, drives alot better but still stalls. Any ideas?02pathy wrote:
