loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Feb 24, 2010 4:16 pm
Do you mean window molding or window visor? As for the sunroof, do you mean the weatherstripping? If you have leaking sunroof, most likely the drain line(s) are clogged. There are 4 drain holes, one for each corner of the sunroof. If one or more drain line is clogged, then water will leak into the headliner and into the cabin. Open the sunroof and blow compressed air into the drain holes and then pour in water (use hose?) and verify water exits thru the drain lines (front drain is close to the lower front door hinge while rear drain is towards the bumper cover, front portion)
The sunroof weather stripping does not seal against water. It's mainly to reduce wind noise.
