bokeninfiniti »
https://forums.nicoclub.com/bokeninfiniti-u70161.html
Fri Jul 06, 2007 2:23 pm
I have an '01 G20 with 160k miles. The car is not a daily driver, mainly for weekends as I take mass transit to work. The last few months the car has started acting up when I try to start it. I had the battery checked and tested and it got flying colors. Occasionally when I try to start the car, I turn the key and get nothing. The electronics power up, but the engine doesn't even roll over. The car will eventually start up after waiting and trying again and again, but I have been stranded for anywhere between 1min to 2hrs trying to start the car. When it does start, it struggles a bit, kind of like a car with a weak battery. I have noticed the same struggling with starting if I start the car, then turn it off, then try to start it again. The car did get side swiped pretty hard, causing damage to the front quarter panel, which is around when I noticed this problem, so perhaps a wire was knocked loose. But what I can't figure out what wire is loose that would cause the car not to start one moment, but will just a short while later. Any thoughts on potential sources of problems?
