loystock »
https://forums.nicoclub.com/loystock-u10145.html
Tue May 15, 2012 12:42 am
Switch Ignition key to ON (not start) and with the radio-ac-blower off, you should be ale to hear the fuel pump humming from the backseat area for about 5 seconds. You can repeat as needed but the pump shuts down automatically after 5 seconds. If the fuse is Ok but the pump is not turning on, then it's a bad pump or related harness. If the pump is running it could be a dirty filter (within the pump assembly, fuel injectors or ignition (are plugs relatively new?). You may need a fuel pressure gauge T-eed between the pump and the fuel rail to check pump delivery (43 psi with Ignition ON, engine OFF; 34 psi with engine running).
Check/clean the main engine harness ground points. Just follow the main engine harrnes and you will find two black wires with lugs bolted to the engine frame.
You may also have a problem with the Security System. Is the Security LED turning off when you switch ignition to ON?
