loystock »
https://forums.nicoclub.com/loystock-u10145.html
Thu Oct 08, 2009 7:03 pm
For OEM parts, best place to buy @ 25% off MSRP is at IoS (Infiniti of Scottsdale) - infinitipartsUSA.com, one if NICO sponsors. However for spark plugs and O2 sensors, the cheapest OEM and quality replacement parts are from NGK.com a.k.a. sparkplugs. com. There is another site, "oxygensensors.com" which offer Universal O2 sensors (require cutting and splicing of wires). If you are not in a hurry, you may be able to get a lower price from Amazon.com. The key is knowing the part number of the O2 sensors that your need. The NGK/NTK, Denso and Bosch sensors are very good but be wary of cheap sensors from eBay. The sensors must be handled with care.
The 96-99 I30 have two emission configuration - Federal and California. Some stores only sell Federal configuration sensors. For 2000 and beyond the Federal and CA configuration are the same.
For 99 CA and 2000 or later O2 Sensors Configuration and NGK.com pricing, see below:
Bank 1 O2 Sensors for Cylinders 1-3-5 on firewall side)-HO2S1-B1: Front 3-wire sensor with BLACK harness, >25" long with sensor mounted on B1 vertical pipe and connector located on top of the engine, rear, pax side, NGK P/N: 24525 @ $68-HO2S2-B1: Rear 4-wire sensor with WHITE harness, >38" long with sensor mounted in front of B1 Pre-Cat and connector located on the radiator side, NGK P/N: 24574 @ $90
Bank 2 O2 Sensors (for Cylinders 2-4-6 on radiator side)-HO2S1-B2: Front 3-wire sensor with BLUE harness, >11" long with sensor mounted before B2 Pre-Cat (sensor is visible in front of engine) and connector located on the radiator side, NGK P/N: 24521 @ $57-HO2S2-B2: Rear 4-wire sensor with RED harness, >29" long with sensor mounted downstream of B2 Pre-Cat (horizontal section of the pipe) and connector located on the radiator side, NGK P/N:24572 @ $93
