alinski »
https://forums.nicoclub.com/alinski-u9017.html
Mon Jul 09, 2007 9:41 am
Hello. The "Service Engine Soon" light came on my 2001 I30 last week and I dropped it off earlier today at the Infiniti dealer to check and also perform an oil change. Just got a call back and there are two separate issues:
Problem 1: Catalytic converter (bank 2) needs to be replaced. Approximate labor + parts cost is $1000.
Problem 2: Power steering hose (on the side of the engine per the service consultant) is leaking and needs to be replaced. Approximate labor + parts cost is $360.
Problem 3: On a previous visit, they detected a leak in the AC hose (located on the bottom of the engine per the service consultant). I have held off having it replaced. Approximate labor + parts cost is $400. The AC has been working fine and it has been between 95-100 degrees here in the last week or so.
I just had the car smogged 3 weeks ago and it passed with no issues. Service consultant said I can hold off on replacing the catalytic converter. I asked her to see if I can save on labor if I have the power steering hose and AC hose replaced at the same time. I have never taken the car other than the dealer for oil changes and repairs. The I30 has around 111,500 miles and has been reliable up to this point.
Question 1: Is the pricing reasonable for the labor + cost? I should probably have other local shops look at it and get other estimates.
Question 2: If you had a choice of which repair to do first, which one would it be and why?
Thanks for you input in advance.Alan.
