While a used V8 may need $3,000 at purchase, a V6 costs less and a FWD V6 even less to fix the DEFECTS that made it up for sale in the first place.
Never buy a used car out of warranty without paying an expert to document the defects found after spending a few hours testing all systems.
The few hundred you pay will make you walk away 2 out of 3 times on the pretty piece of junk offered for sale.
Used I30 on the whole are some of the best used car products out there, if 66% have problems hopefully you understand how bad the other 7 years old are treated by owners.
Be sure to have a hydrocarbon test [combustion gas leakage] done to coolant to make sure the head gaskets are ok [from a previous overheat].
http://www.reds-headers.com/ht....html
"Overheating is usually from combustion gases leaking into the coolant. If there is coolant in the system, the water pump impellers are turning, and the radiator is not plugged, suspect combustion gas leaks.
In the above example, the reason I suspect combustion gases leaking into the coolant is because the overheating comes with increased load on the engine. This can happen even though the leak is small, and there may not be any water in the oil or visible water vapor in the exhaust. The cylinder pressure goes up with throttle opening. This increased pressure may cause enough hot gases to push into the coolant that the radiator can't get rid of the heat fast enough. Then the temperature goes up and up, unless the load is decreased."
While I have sympathy for the young on buying a used car, 56 year olds having driven for 40 years should know better in not having an expert prebuy analysis!
For about 20 years Nissan has used a fail open thermostat, that if anything causes a slow warm up and cold heat in winter.
