maxhopper »
https://forums.nicoclub.com/maxhopper-u11180.html
Sat Aug 01, 2009 7:12 pm
If you can operate a flat-head screw driver, you can replace your own MAF. Once you see it, you'll know where it goes (on the intake piping from the air filter to the throttle body).
As for eliminating the cat...it depends on which one you're talking about. There are two precats (one for each exhaust manifold), and the main cat. A y-pipe or headers will eliminate the two precats and give added performance. If you are wanting to replace the main cat, I would recommend a hi flow cat, or take it to a local exhaust shop and see what they can do for you.
