2001 I30 control arm questions
J0SHYee
Car: 1991 240sx
2001 I30
do i need new bushings? or should my control arms wiggle like this...
http://www.youtube.com/watch?v=HJSqQxIudKA
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Yes
No
Just guessing, you probably need new control arms/balljoint & inner and outer tie rods & connecting rods & stabalizer bar bushings too
Start with the floor shop manual to see if you need a new front end.
How many miles on the ride?
http://www.nicoclub.com/FSM/
dbaxRonin
Car: 2016 Infiniti Q50 Red Sport 400
2010 Infiniti G37x AWD Coupe (Traded in)
2001 Infiniti i30L (Traded in)
I just had my control arms replaced due to worn out ball joints. They can be had for pretty cheap and the labor to replace them is pretty minimal. I got mine through RockAuto.com for around $50 a side if I remember correctly (maybe it was $75). At the very least you need new bushings in there, but I would wager if the bushings are that bad, your ball joints are probably pretty worn too so you may as well do the whole thing in one shot. I also had my tie rod ends, and sway bar linkages and bushings replaced at the same time.
