nutsnbolts4u »
https://forums.nicoclub.com/nutsnbolts4u-u137993.html
Thu Jul 09, 2009 11:46 am
It seems that if something like this happens often enough then Inifniti needs to correct the problem. I have seen other posts where maybe a fire didn't happen but the ECM got fried because the idle air control valve shorted out. The mechanic hasn't found everything that burned. But I expect several thousands of dollars and extensive damage. He is even saying that the electronic motor mounts could have gotten it too or could have been another cause of the ECM being burned. So far I have to replace the idle air control valve, the ECM and the battery (yep-it got fried). Anyone have a contact at Inifiti headquarters that I can call?
Modified by nutsnbolts4u at 2:52 PM 7/9/2009
Modified by nutsnbolts4u at 5:31 PM 7/9/2009
