cheepnis05 »
https://forums.nicoclub.com/cheepnis05-u120677.html
Sun Nov 23, 2008 4:48 pm
OK; so here is the ultimate issue...
The RAP "Retained Power" function that allows the operation of the windows for 45 seconds after turning the car off, relies on a diode that only allows power to flow to the window relay and not also back to the lead from the ignition switch back to the SECU.
That diode was burned out and had been jumped by the CROOKS AT 'COMPETITION INFINITI' OF SMITHTOWN, NY.
So the RAP was supplying power to the SECU terminal that was expecting none, hence the RAP never turns off!!
I can close the windows with the key in, so I just clipped it. The next time I have the dash open I will trace and replace the original diode or rewire as necessary. The important point is, all the other systems are operating properly because the SECU now knows when the car has been turned off!
-Tim
