Yes it could be you have a faulty ignition switch and I would also check your battery connection. Make sure the terminals are clean and you have a good ground. Are you getting a click-click sound at the starter when it does not start?cucumeh wrote:Thanks again, Yes I have done all of that. Could it be the ignition switch?
The ignition switch could definitely be the problem then!!!cucumeh wrote:Battery is new, connections are secured. No clicking sound or any other sound.
It's on page 559 herecucumeh wrote:I replaced my ignition switch...that did not solve the problem. Now I got a nutral switch, can you tell me where is this unit is located? any help would be greatly appreciated.
