Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Oct 19, 2009 7:30 am
cranking the bars doesn't tighten the suspension up...it just raises the working range. The reason you get a harsh ride from cranked Tbars is that you eliminate most of your down travel. That said, is it still using the stock upper A-arms? Being a 2wd, the problems shouldn't be quite so dramatic as they are with a 4x4, but if it's been that way for 6 years, my guess is the steering centerlink will be worn. That's about $150 for a new stock one and a little know how with a wrench and BFH to replace it.
Since your buddy has had the truck that long, find out if the transmission has ever had a fluid flush. 89k without one isn't good, and will likely affect the remaining life of the transmission. I also wouldn't pay that for a non-running truck. Have him put the new distributor in so you can check out the truck, drive it, etc. and look for bugs. If he's not willing to do that, look elsewhere. I assume you still want to be buddies with this guy after the sale, so make sure the truck is sound, or else that friendship is in jeopardy.
