Scandinavian Flick »
https://forums.nicoclub.com/scandinavian-flick-u100311.html
Thu Jul 24, 2008 6:35 am
well i dont know what trouble shooting you've done but here is a good place to start,
remove the intake hoses all the way up to the throttle body, with some one cranking the engine spray starting fluid into the intake manifold, if the car starts then its a fuel delivery problem, if it doesnt then its a spark problem, this isnt true in absolutely all cases, but the majority of them,
if it seems fuel related, check your fuel pump relay, fuel pump, and fuel filter
if it seems spark related you can buy spark testers, which plug in line with the spark plug wires and will flash every time a pulse is sent through them, this will at least tell you if it is sending a current to your plugs,
also make sure its not something stupid, like the rotor is missing from inside the distributor cap, or something simular,
also check your spark plugs, they can tell a lot about an engine, if you pull one and its wet, then there is no spark going on,
well without having any more info , that is where i would start,
good luck
