unk »
https://forums.nicoclub.com/unk-u68078.html
Mon Jun 18, 2007 9:54 am
Recently bought 01 Altima, unknown history, 90k mi, engine and trans strong and quiet. Runs routinely at 900-950 rpm, A/C on or off. Occasionally drops down to abt 650 rpm, idle is not rough. Had a similar prob. on a 96 Escort. Fixed w. new TPS after review of Haynes manual. My gut tells me this one is not that simple. Found too many other possibilities after a bunch of internet mining. Intake gasket leak?-----expensive labor. TPS?----$110, but Haynes says it needs to be set properly with a multimeter. Idle speed control valve and gasket?-----$175 + labor. MAF sensor?----didn't check pricing. Vacuum leak(s)? EGR valve? Note that the CEL has not come on so I don't know if the system is sending any codes. Since it has 90k mi I thought I would replace the O2 sensors as maintenance. I'm somewhat anti-dealer but do you think I should just take it in for a plug-in diagnostic? The other issue I have, as many others have written, is poor gas mileage. Just checked it and only got 21mpg.......and I'm an easy driving slow poke. So, with all these possibilities in mind, I need some expert opinions on a proper plan of attack ASAP. Don't want to just start throwing money and parts in it without some good reasoning. Thx----unk
Modified by unk at 11:43 AM 6/19/2007
