Timothy S »
https://forums.nicoclub.com/timothy-s-u242199.html
Sat Mar 28, 2015 7:59 am
According to the Hanes manual, the Altima's Backpressure transducer is connected at the top to manifold vaccum off of the egr valve control line. the bottom is connected to the Exhaust gas line in the manifold. When the engine is accellerating, exhaust backpressure closes the transducer's normally open leak to the atmosphere, allowing the vacum to open the egr valve.
In your test, the EG transducer should have held no vacum at the top port. The lower port should receive pressure when the engine is running. The pressure at higher RPM should become high enough to make the top port hold vaccum. This is a safety to prevent a vacum leak to the intake manifold caused by a egr valve open at the wrong time.
Have you tried moving the egr valve by hand- touching the diaphram? you can feel it move when you rev the engine if it is working properly.
If you clean anything, it should be the seat for the egr valve itself. This is a last resort, as the bolts are hard to remove and you'll need a new egr valve gasket.
