loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sun Aug 09, 2009 9:22 pm
The problem you are having is probably due to improper servicing done to your AC system. Since you system has been empty for a while, that means the lines have been exposed to water vapor (ambient air) and contaminants. The dryer (aka liquid tank, receiver, etc.)) has a dessicant which extracts moisture from the system and is probably saturated with water. The fact that the your mechanic simply recharged your system without evacuating it means that water and contaminants are still present in your system. Your AC is showing symptoms of excessive refrigerant, water presence and or probable contamination.
Water freezes once the evaporator discharge temperature goes down, clogging the low-pressure line. Contaminants, if present, may cause erratic expansion valve operation, resulting in frost in the lines. The same thing happens when you have too much refrigerant in your system, Anytime the system has been exposed to ambient condition for extended period, replacement of the dryer is a must. The compressor in your car has variable displacement. The compressor stroke varies, depending on set temperature, ambient condition and other parameters. If the stroke is always at maximum, then you will have very cold output from the evaporator.
So the best thing you can do is to take your car to shop with certified AC technician. -Have your system evacuated properly and fix any leak if still present.-Replace the dryer-Inspect/clean/replace the expansion valve of possible contaminants.-Evacuate the system again for at least 30 minutes (the technician should know the actual time required)-Add the required amount of AC oil and refrigerant.-Test the AC system - doors closed, windows open, AC in MAX COOL, MODE at pax vent, and air intake at RECIRCULATE With ambient temp @ 86F and humidity at 50-70%, the discharge temperature at the AC central vent should be 56-68F, Low Pressure at 31-37 PSI and High Pressure at 149-185 PSI. Please note that the temperature and pressure will vary as a function of humidity and ambient air temperature, etc..
The actions above should fix your AC system. If not, there is a built-in AC diagnostic which you or your technician can use to further isolate the problem, The detailed procedure is given in the FSM (Factory Service Manual) which is available for download from this site. It's covered in HA (Heating and Airconditioning) chapter.
Had your system been serviced properly, you could have simply gone directly into the built-in diagnostic. But it is impractical to do diagnostic if you know that the system may have too much refrigerant, no AC oil, presence of water and/or contaminants.
