When you first fill the the empty engine with coolant, place the heater temperature control in the maximum heat position, to be sure the lines to the heater core are open, and be sure the air relief plug is removed. Coolant should start flowing out of the the unplugged air relief hose. If nothing comes out of the hose, the hose is probably clogged which is trapping air in the system. This is the first step in filling the coolant system.
There are two coolant temperature sensors on your engine. The engine coolant temperature sensor on the block sends its signal to the ECM for engine controls. The other temperature sensor is connected to the same piping, at the back of the engine, that the air relief hose is connected. It's signal is sent to the temperature gauge on the dashboard. When you drive downhill, the trapped hot air rises to the highest point of the engine, which is that piping when you are driving downhill. Since the air is hotter than the coolant, your temperature gauge immediately reads as overheating.
* After slowly filling the cold engine with coolant until coolant flows out of the air relief hose, put the plug back onto the hose and continue to fill the system until coolant reaches the base of the radiator filler neck.
* Add coolant to the reservoir, up to the MIN or FULL COLD line.
* Wait 5min or so and recheck the coolant level in the radiator, adding more if necessary.
* Leave the radiator cap off and run the engine until the thermostat opens. (The upper radiator hose will become hot.)
* Rev the engine to about 2500rpm for 10sec then let it idle. Do this a few times.
* Turn the engine off and let it cool.
* Add more coolant to bring the level back up to the base of the filler neck.
* Squeeze the upper radiator hose to expel air, then add more coolant if necessary.
* Reinstall the radiator cap and add coolant to the reservoir if necessary.
* Start the engine, allow it to reach normal operating temperature and check for leaks.
These are the steps from my Haynes Repair Manual.
The Nissan factory service manual steps are similar but that has you putting the radiator cap back on before starting the engine and then repeating multiple steps until the coolant level in the engine stops dropping. (see page MA-16)
https://www.nicoclub.com/service-manual ... 1%2Fma.pdf
I like the Haynes method better because it allows you to burp the system out of the open radiator and avoid having to repeat multiple steps and the FSM mentions nothing about setting your heater control to maximum, which is important to be sure air in the heater core is expelled and burped out. The choice is yours, but do it by the book. Either one.
