Leonard4 »
https://forums.nicoclub.com/leonard4-u222995.html
Wed Jul 11, 2018 10:38 am
Just finished the driver side strut/spring replacement lastnight (2hrs), I had done the passenger side on sunday (6hrs). Grossly underestimated the amount of time and effort it would take using those spring compressors. I ended up getting an air wrench for the drivers side, which is why it took way less time, plus I knew what to do this time around. I did run into an issue with the new KYB Excel-G struts, one of the spots to screw in the brake line wasn't a threaded hole, it was a pressure fit spot now to squeeze the hose into. Also the control arm bushing that mounted up high was frozen on both struts, had to use a hex key with a box end wrench with 1/4 turns to break that out.
Old struts were 100% failed, I could compress them with 1 finger, and when I lifted it up it would drop back down itself with no pressure till about half way. New springs were Moog springs, larger springs, but shorter overall, also did not have a flat top on the coil like the stock springs had. Assembly and installation wasn't bad, put it back together the way it came apart for the most part. There was what seemed to be a paper gasket on the top of the strut mount that was inbetween it and the inside of the wheelwell frame, it was brittle and disintegrated as I took it off, I did not have a replacement so hopefully I don't get any squeaking. I jacked up the side with a floor jack, then a jackstand under the pivot point on the control arm. I used a 12t bottle jack to raise and lower the bottom of the rotor to slide the strut bolts out and get that control arm nut off. The large strut bolts were rusted to hell and back, would advise a good penetrating oil soak for at least a half hour, I still had to use a sledge and a breaker bar to get mine loose.
Ride impressions, feels like night and day, no more bouncing, almost no rebound on bumps and stopping and accelerating don't nose dive the front end now.
