nissan2986 »
https://forums.nicoclub.com/nissan2986-u178989.html
Wed Oct 10, 2012 4:12 pm
I recently had an independent mechanic clean the battery terminals after fixing a P1320 code. He said take it to a Nissan dealer to fix the P0505 code. The Nissan dealer charged me $120 to "diagnose" my car, but they didn't look into the P0505 code like I had asked. They just said I need fluid changes, a ball joint and cv boot, repack bearings, brake fluid change, pads, and this will cost $2000. They said for P0505 diagnostic I will have to leave the car 4 hours. They said it is possible the previous mechanic did not disconnect the batter in the right sequence which shorted the computer. Is that even possible? I did not have the P0505 before taking it to the first mechanic. Just the P1320 and an O2 sensor code. The next day I get a call asking me if I want to trade in my car for a new one... crooks.
It is possible the previous mechanic did not disconnect the battery cables in the right sequence and fried the PCM/ECM/ECU?? Since the dealer was no help, I bought a chilton manual. I checked the resistance on all terminals for the ISCV and I had ~24-~25ohms. The connector going to the ISCV had power so that seems ok.
Next I checked the connectors going to the TPS. The orange one was ~5v (fine according to the chilton manual), but the second gray connector didn't show any voltage reading. Where does the power for this gray connector come from? If I don't have power going to the gray connector on the TPS, will that trigger a P0505? Can I open the ECU up and re-solder the TPS circuit myself? Is there a reputable pathfinder ECU rebuilder? Some guy on ebay is charging $200 to take my ECU, rebuild it and mail it back. Is there a guy with a reputation out there if indeed this is my problem?
Thanks
