2001 2.4 Fontier Check Engine Light On [please help]
budstang50
Car: 95 Mustang GT-2001 Nisson Frontier
Check engine code PO301. Recently changed spark plugs wires cap & roatar . Still check engine light is on. Truck still rides a little rough. I know the code reads No.1 cylender misfire.
PLEASE HELP
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
did the light come on after or before you did the work?
if it was before, diconnect your battery for an hour to clear the code and see if it comes back.
budstang50
Thanks I'll try that tonight when I go to work.
budstang50
It comes right back on. Still check engine light on. Also the light was on before I did the tune up.
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
Pull that #1 plug and see if the ceramic portion is cracked. Ensure the wires are plugged in properly.
You can also trouble shoot by replacing your new wire iwth one of the old ones on cylinder #1.
Did you use OEM parts?
