Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Tue Aug 27, 2019 6:39 pm
I'd try and get a 2002 or newer R50.
2001 was the first year of the VQ35 engine, and it had it's teething problems.
2002-2004 are the most desirable.
Rust is indeed a big issue, so if you can find a southern car that hasn't seen salt and ice, then that's where I'd look.
The pre 2001 R50's are under-powered, in my opinion. The smaller engine requires more maintenance (timing belt in particular), so I'd shy away from them if you can afford the newer ones.
