nismopu »
https://forums.nicoclub.com/nismopu-u29994.html
Sun Nov 02, 2008 11:24 am
yeah they can be a pain! How did you guys come to the conclusion the speed sensor is bad? Theres an O-ring in there that can hold it in pretty good, get some rubber gripping fuel pinching pliers and try and spin it out by moving it back and forth. If that doesn't work and you know the sensor is bad tack weld a nut on the end of the steel casing the sensor resides in. Then try and work it back and forth that way to. peace.
