2000 Xterra carburetor conversion
Beermoney
Car: 2001 Infiniti QX4
I want to know if there is an intake for a 3.3 to convert to carburetor. 2000 Xterra
Reason: Revise Title
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
the VG has been an EFI motor since it's inception.
Why would you want to go backwards?
Beermoney
there is a carb available for 3.0. i don't know if it will bolt on 3.3
alexg89
Car: 95 Hardbody
07 Frontier
Kick up an intake for an old TBI style and then youll need an adapter for put on a carb.
used this dizzy
https://performancedistributors.com/pro ... stributor/
and you should be good to go .. buddy of mine did it with his truck. has a blow through set up
Beermoney
thanks Alex. Was that a 3.0 or a 3.3. I am pretty sure that the blocks are the same. Not sure about intakes.
Beermoney
Thank you Alex. Was that a 3.0 or a 3.3.
alexg89
Car: 95 Hardbody
07 Frontier
Its a 3.0 but the intakes are interchangeable .. main differnence on them is the crank snout is longer, cam and crank gears (round vs square teeth) and the exhaust manifold bolts are 10mm vs 8 mm .. but intake stuff is the same
Beermoney
that's what i wanted to hear. thanks.
