2000 Xterra AC problems
softball nut
Car: 2000 Xterra
Okay guys, new here but lookin for some info, like a wiring schematic. Daughters Xterra AC not workin. Clutch not engaging for compressor, relay is energized but no clutch. Any help ?
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Check your email for the entire electronic section of the Xterra's heating and AC systems.
softball nut
Car: 2000 Xterra
Big Bird, thanks for info. Lot's of help. Something wrong in control circuit to clutch, can troubleshoot it now. Thanks again.
2000nisfrontier
Car: nissan frontier
Does the A/C ever work or does it always blow hot air? I had similar problems on my 2000 frontier. The a/c would work fine and then out of the blue it would shut off and blow warm air. I traced the problem to the THERMAL CONTROL AMPLIFIER. $60 to $70 from dealer. Takes 15 min to install, Air works like champ now! anyway may or may not be the problem, check it out.
