tunahLou »
https://forums.nicoclub.com/tunahlou-u70995.html
Thu Jul 26, 2007 6:21 pm
Ill try the relearn but, it seems like its a worse problem than a simple relearn..its doin the same thing it did before the maf was put in..and something is drawing the battery dead...plus the alternator quit..lots of problems at once...but the running issue..this is what i did last nite..with the battery charged and a charger on it...i can start the car..runs kinda ****ty sum starts others it runs fine..put it in gear runs ok...give it throttle and it dies rite out..if i feather it real fast i can get like 2000 rpms out of it...it acts like its running out of fuel but i tested the pressure and it seems fine...around 45-55 idle..the stumper of this car is it all started when the alternator died..ive checked all grounds..fuses,,etc..seems like im missing something but every sensor is putting out on my scan tool and nothing is dropping out...i dunno Im a good tech maybe all this heat is gettin to me
