Thanks for the feedback. Ill look into getting the uv dye today and test that out to see. After I finish replacing the trans filter n fluid. If that is the case that it’s oil, I just have to replace the seal?VStar650CL wrote: ↑Sat Dec 11, 2021 11:27 amThat's the bell housing. Oil there can be from either the transmission front seal or the engine rear main seal, so it's important to identify what it is, engine oil or transmission fluid. The simplest way is to put a bit of UV dye in the engine oil and run it for awhile. If the drips glows then it's engine oil, if not then it's the transmission.
Yea a harsh lesson learned for me. Right prices are insane right now. When I checked the carfax b4 purchase it actually said the value was roughly $5-6k. After everything play out, i'll look into the AT-205 if needed. So I havent already replace the fluid, I just drained it for now and going the replace the fluid after I reply. When I cleaned the pan I didnt see any metal fragments at the bottom but the magnet was covered in black "sludge." As I was wiping it off, I noticed the fragments on magnet that I couldnt get off. I wouldnt consider it a lot but have no idea. So yea ill pray it goes in reverse after replacing fluid. It definitely wont be worth getting the transmission rebuilt. Fortunately, that was the only code, so good to know thats the least of my worries. Thanks for the feedback and suggestions. I'll finish up and hopefully update this with some good news. Thanks again fellas.MisterH wrote: ↑Sat Dec 11, 2021 11:58 amSorry you made a hasty purchase and got stuck with a car that may not be worth fixing. I feel for anyone having to deal with buying used cars right now, as prices are insane. In my region, 20 year old Pathfinders and QX4's that don't have serious issues are $5-8K. If you determine that it's an oil leak from the RMS There's a product called AT-205 that has a decent reputation and there's others like Blue Devil or Bar's.
That said, the more immediate concern is the transmission and in all probability it's in need of a complete rebuild, given your mileage. You could take it to a mechanic for a thorough diagnosis but since you've pulled the AT pan off you could check the bottom of the pan. If you see a lot of metallic fragments it would confirm that your clutch packs are burned up and the AT needs to be rebuilt. In your description you didn't make it clear whether or not you have already changed the AT fluid. If the amount of metal fragments is insignificant you could just put in new AT fluid and pray that it goes into reverse.
You could get an estimate on a transmission replacement but it'll probably be more than the value of the vehicle. The cheapest route would be to source a good used transmission from a dismantler and pay a good shop to install it. I believe it takes roughly 10 hours to R&R the transmission. The one benefit if you were to go that route is that replacing the transmission can also address your rear main seal leak. Lastly, ignore the P0325 engine knock code for now - that gets triggered anytime the ECU detects another error like a misfire or some other significant fault that will affect engine performance. Unless you have another error code present it's not going to affect anything by itself. Good luck to you.
Cosmetically its pretty good. Only noticeable problem is tears in the driver seats. Body is good. Can tell it was well taken care of.
