2000 quest intermittent rough idle
A forum for the Nissan Quest... minivan lovers unite!
popeye213
i have a 2000 nissan quest. it has a intermittant rough idle only after sitting at a light for a min. It was idle fine at light then just start idleing really rought, i have to rev it up and then drive. The van has a new iac valve, throttle position sensor and egr valve. It had the issue before these parts were changed as well. There is a check engine light p0135. 02 sensor light, both sensors are brand new. light is still on. Any ideas?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Try running some fuel system cleaner containing polyether amines, which is a chemical proven to clean deposits without leaving behind its own residue. Products which are known to contain PEA are Chevron Techron, Gumout Regane, and Redline SI-1.
Try cleaning the throttle body if you haven't yet.
For the P0135 code, follow the diagnostic procedure on page EC-225 of the factory service manual.
Welcome to NICO.
Return to “Quest Forum”
