IceCubeFoSho »
https://forums.nicoclub.com/icecubefosho-u83001.html
Fri May 21, 2010 3:29 pm
I haven't posted here in ages since I let my mom have the Q45 as I've got an 06' Xterra now.
In any case, I've come back because there seems to be a problem with the Q now.
The car's battery has power and I ran the radio, A/C, lights on and everything for a good few minutes while checking speeds of windshields going up and down to make sure the battery actually has power, and it does.
Then when I try to start up the engine, I either hear the clicking or later on, I'll hear the cranking going slow slow slow slow medium medium slow slow medium medium faster faster medium faster faster faster Vrooom engine starts. Keep in mind, this only occured once out of the 4 times I've tried starting it, and its pretty much not starting anymore.
IF I put the jumper cables on, the car starts like its nobody's business, but when I take them off, it cranks so slowly which leads me to believe its a starter problem. You can also drive with the car fine once jump started, but once you turn it off, it refuses to turn on, or it cranks for a very long time and finally starts.
Am I correct in thinking its the starter?
Its also got about 113K miles, maybe more, if I remember correctly.
Any ideas/tests I can do further to make sure its not something else?
Thanks in advance.
