2000 Q45 update and questions
MarshallQ45
Car: 2000 Q45 115k - with issues
I posted a while back about my Q's problems
I took it to a close shop to have it inspected as it was making a funny howling sound.
They say the car has been lowered too much and it is causing the steering rack to bind internally.
They recommend new rack, steering pump and out tie rod ends and of course to put original springs back on. I guess it has tein s techs but they have had a coil cut off of them, so it has a 3in drop about or just less than 3in.
Just want an opinion on what is best to do.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Most people in here will probably recommend you go back with the original setup.
Try asking your question here ...you might have better luck:
vip-forum.html
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Marshall you should take your car somewhere else. It sounds like that place runs like a dealership except the people there are not nearly as qualified to work on automobiles of any kind.
See what the dealer says.
