2000 Q45 missing one day after service
rich4ard
Car: 2000 Q45 1985 300zx
Hello and thank you in advance.. I own a 2000 Q45T that’s been a very nice car to have.I purchase this car with 30,000 miles on it 2004, now she has a 138,788.I had a dealer service at 60,000 O2 sensor at 83,000 and change the oil every 3000 miles,
The car was driven by my wife only starting out, and then economic times hit us hard. The Q45 became our only source of transportation,I was not able to have the 90,000 nor the 120,000 but I keep the oil changed and clean air filter and I only used premium gas.
This summer if I was idle and the air conditioner on the temp gauge would move a little passed the middle but never get hot, but I ‘d turn the air off and the gauge would go backnormal.
As the GAS prices has come down, that’s going my chance to get my Q service. So now I began to smell oil burning I find out the valve cover gasket is leaking and she started missing, I know that I can’t afford to take her to the dealerAnd the shops in my area were charging more than I had to spend. I found a mechanic To do the service and valve cover gaskets.
Now by this time my Q is not running to smooth (service engine soon) light was on, I had it checked out misfire #1 cylinder.
Now let me get to why I’m writing last Saturday the mechanic did the service, changed plugs all fluids and filters and the valve cover gasket, So that night I pick up the car and drive it around town WOW what a nice riding Q45I almost drove out of town the ride was so smooth, acceleration was on the money, when idling you did not know the car was on.. perfect. Sunday morning, proud owner of a great riding Q45, pull up to the store to get a paper put her in park WHY DOES SHE START MISSING don’t understand running so smooth then back to missing, the mechanic suggested I try some gas treatment I did STP Plus. Didn’t work and last night the service engine soon light came on, I will get that checked today.
I did buy ngk platinum plugs as recommended by Infiniti dealer here in TX. I wondering did something disconnect or should I put a knot on the mechanic’s head well maybe not before he takes a look at the Q .
Sorry for jumping all over the post, any suggestions will be appreciated
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
First, relpace the plugs with the OEM recommended NGK PFRG immediately!
When you do, switch the coilpacks between #1 and #2. Then be vigilant after the ECU is reset for another CEL and report back where it indicates a cylinder misfire.
Way past time to clean EGR, IAC, TB plenum and lower runners, but you can do it your self with gaskets and tools including a good torque wrench.
When did you last mechanically exchange the ATF and PS fluid?
Q45tech
Non expert technicans and especially mechanics may not be careful in removing coils when changing plugs accelerating coil failures.
Any miles after 100k are a blessing.
Q451990
Coil packs seem to be the Y33's timing chain guide issue. Many, many, many members have reported random misfires that have been cured by replacing all 8 coils with OEM new parts.
Heath
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Q45tech wrote:Non expert technicans and especially mechanics may not be careful in removing coils when changing plugs accelerating coil failures.
I removed mine like I was building a house of cards and it still created a misfire. How do you explain that big guy? I have a guess-sometimes your wrong.
You have a failed coil, buy a new one and replace the coil on cylinder #1 and count your blessings that you got a code for yours. The others may last longer but be prepared to replace all of them if you keep the car. Its expensive but may be easier to replace all at once since you don't work on your own car but your call.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Maybe you removed a failed coilpack?
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
As I've said in past threads on this subject, I do remember reading in these forums years ago that coil problems may surface more readily after replacing spark plugs.
Why? No idea..leave that to the experts here.
However, it perfectly coincides with your symptoms, and with everyone's proposed solution.
Modified by paranoidjack at 5:51 PM 12/18/2008
qship96
Car: 1996 Infiniti Q45
Just another good reason not to be in the habit of replacing sparkplugs too soon- everytime you remove coils to get to them you risk damaging the coil!. My Q will make it to 299,999 miles with only 2 plug changes total, instead of factory recommended 4 changes.
