You can get four-wire Bosch universals for cheap @ RockAuto.com. All you've gotta do is wire the connector to match the stock configuration. New O2's @ 90+K are ALWAYS a good idea...BadQ45t wrote:How many miles do you have on that 2000? Just wondering, I haven't had any issue yet at 93k on my 97' but when I do new plugs I am thinking of O2 sensors at the same time.
The compression in cylinder #2 is about 1/2 compared to other cylinders. I think this is a problem. Looks like it's a valve.Lokim wrote:m45- I forgot to mention, after you figure out and repair why bank 1 is running rich, get the car on the highway for 25+ miles at 60+MPH and when you get back home, leave the car running and read the O2 values while the car is HOT! You may actually be able to blow the crud out of that cat with high RPM driving if it isn't too bad...
I'll do it, Lokim, good idea.Lokim wrote:Do a leakdown test on that cylinder. If you hear air escaping into the oil pan or V.C., the rings are bad. If air is escaping via the intake = bad intake valve, same for exhaust. Pull the V.C. after the leakdown if it's coming from intake or exhaust and check and see if an HLA is stuck all the way pumped up...
