todapark »
https://forums.nicoclub.com/todapark-u99062.html
Fri Jun 13, 2008 5:11 am
My 2000 pathfinder has a clunking noise in the front drivers side wheel area when going slowly on a dirt gravel road and also when going uphill on a paved road at highway speeds the right tire seems to shimmy ie vibrate and stops when going straight . It has new balanced tires and is all original. I took it to a shop just for a diagnosis and was told it was the tie rod ends, replaced them and it still has the same issue, then was told it is the swaybar links and swaybar rubber mounts, ditto, replaced them and still the problem exists. Then was told it could be the strut mount bearing (plastic), I pulled the strut and found just the slightest play between the coil spring top mount and the strut mount with the 3 bolt studs on it, the plastic bearing looks ok but as said it has just a very small amount of play back and forth. Another possibility is the wheel hub bearing, jacked the front end up and yanked on the tire top and bottom and there again is just the slightest play, about what used to be normal on the old cars with angled bearings. The shop said they didn't think it was a bad hub bearing because normally a bad bearing will make noise, click and will wobble (shimmy) when going straight and then stop when turning due to the load placed on it when the vehicle is turning at highway speeds. I am tired of replacing parts only to still have the problem and am getting frustrated, I like the Pathy but with older cars when something failed well it failed, this thing has a problem yet all the parts seems ok but only with the slightest of play as mentioned. Ok thats the long story so my question is, could the plastic strut bearing with just a tad of horizontal play cause the clunking noise I hear mainly when going over bumps and especially if going slowly on a gravel road? Or any other ides? thanks, burning thru the parts toda
