atraudes wrote:ether
I'm sure it's a typo, but I can't think of the replacement word. Other? (If so, still not sure what you mean, sorry.)
If the engine were heated up, compression alone could ignite the fuel (that's what occurs in a ping situation). But with immobilizer, there's simply no fuel being sent. That's what makes it tricky...it replicates a fuel pump issue, but is far less obvious.
I've had three conditions where I could crank and not start:
1. Throttle position sensor code. Occurred only after the engine was heated to normal temps, then turned off.
2. Random crankshaft position sensor code. Put my truck into limp mode while driving, can't be restarted when turned off.
3. Relocated the key's immobilizer chip into one of those flip-out key fobs combos. Truck didn't like that, just wouldn't start. Had to re-learn the key for some reason.
