rgk »
https://forums.nicoclub.com/rgk-u245656.html
Wed Feb 11, 2015 5:57 pm
Sorry, I meant checking for spark or testing your fuel pressure.
You can check for spark by removing a spark plug wire, putting a spare spark plug in it, and holding it with insulated pliers a quarter of an inch from the chassis. Have an assistant crank the engine and watch for a bright blue spark jump between the plug and the chassis. For added protection you can wear insulated (rubber) gloves. The ignition coil provides 40k-100k volts, so be careful.
Another way to check for spark is to remove the intake hose upstream of the MAF sensor and spray starter fluid while an assistant cranks the engine. If the car attempts to start, and runs while you spray fluid, you have spark. If you have spark, then you either don't have fuel pressure, or do have a huge air leak.
To test the fuel pressure, you can rent a fuel pressure gauge from an auto parts store. I'm not sure about your Pathfinder, but for my 3.5L R50, the recommended place to affix the gauge is just after the fuel filter. Ask the auto parts store guys for more info.
