2000 Pathfinder SE
ricke
I recently started having a problem with my 2000 Pathfinder stalling (in gear, stopped with ac running) at red lights. Not every time. Sometimes the rpm just drops to about 300, then jumps back to to 800. Had full tune up at 60K Now at 65K. Runs fine on roads and hiway. Any ideas?
NISTECH
wiggle your air flow harness where it is tie wraped to the intake tube see if the engine stummbles. if so loosen the tie wrap and give the meter side some slack on the harness and resecure it.
