hoobasan »
https://forums.nicoclub.com/hoobasan-u238386.html
Mon Jul 07, 2014 7:30 pm
I love my pathfinder, but I've had an issue come up that (while I can deal with it, the wife apparently can't) - on the passenger door, the electronics seem to have stopped working. Passenger window switch won't work to lower the windows (unless you really jam on it), while the driver side switch will work fine. The lock on the passenger side only works manually, not via the lock button (on any door).
I'm guessing that it's likely wiring? Is there a decent way to test it before ripping the door apart? I'm decent with electronics, but my mechanical skills are in the 'I can make it work eventually' category. Hence I want to avoid having the door torn apart for an extended period of time.
Thanks!
