cminor9 »
https://forums.nicoclub.com/cminor9-u168720.html
Thu Mar 22, 2012 5:48 pm
Hey guys, my Pathfinder has been acting up again.
It had been running kind of rough, loping a bit at idle for the last two weeks. Also, it would occasionally die at idle (like at a light) sometimes if I don't get the RPMs up above 1000. It'll always restart with no problem. A few times it has hesitated a bit under load. I was driving on the highway and it didn't die, but it hesitated a few times and then the engine light turned on. It didn't quite feel or sound like a misfire (have had misfires in this car before due to a fuel pump), just a little bit of hesitation.
I found a small crack in the plastic intake tube right before the throttle body. I took the intake tube apart, cleaned it up, and put a small dab of blue RTV in the crack and reattached it. I thought that would fix the problem.
I just read the codes: P0325 and P0133. I know the knock sensor is a pretty common problem on these. The O2 sensor has showed up before as being slow.
Plugs, wires, fuel filter, air filter, distributor cap, fuel pump and screen were all replaced in late 2010.
I am kind of nervous about just replacing sensors, because they could just be reporting problems from other systems. If I have to, I had kind of been leaning toward trying the O2 sensor first, though, since it's easiest and cheapest to replace. Any other ideas before I just go throwing sensors at the problem?
