silvermullet »
https://forums.nicoclub.com/silvermullet-u135002.html
Tue Feb 20, 2018 7:24 pm
hello all,
sorry to revive old thread but im having a similar situation with my pathfinder. wondering what came about this @FubarGrn.
current situation:
cranks but no start. it happened last monday night. towed it back home. between last monday and this past sunday, no start, just cranking.
initially thought battery. since it is possible for an older battery to not put out sufficient CCA's to start the car in very cold temps, i bought a heavy duty jump starter. didnt work. Im smelling fuel after cranking and hearing the fuel pump prime before cranking. so initial thoughts are its getting fuel. opened up distributor cap and rotor. they werent in terrible shape, but changed them out anyway. checked spark using an inline spark tester between cap and spark plug. it lit up so there is spark. now im sure it was a freak thing, but when i setup every to test spark with the tester yesterday, it started. actually drove it around the block but it stalled out as i was pulling into the driveway. back to crank, no start status. so... getting back to the battery... i decided for sh*ts and giggles to have it tested. turns out it was bad and not putting out enough CCA's on its own. So i replaced it today. Nothing. also.. though im smelling fuel and fuel pump sounds normal, in the remote case that the fuel is not getting into the engine properly, i sprayed starting fluid into the throttle body and tried to fire her up. Nothing.
so doing my due diligence,
1) its in the back of my mind that it could be a bad distributor... all my research has been pointing me to 'if its getting spark, then the distributor is probably fine' but because of that sensor in there, i realize it could still be bad. so would i still get spark even though the sensor is bad?
2) I've read on here as well as other places that if the timing belt skips a tooth and timing is off, it can result in crank, no start. but it sounded fine and seemed fine when it did start up yesterday and drove it briefly. if timing was off when it initially died, wouldnt it not start up at all?
im going nuts here.
thanks in advance for any help!
