Thanks just ordered the clear corners. Appreciate the help.Alfredo24.pr wrote:Welcome to NICO!
1. Ebay.com
Search for: 2000 nissan pathfinder clear corners
They cost about 35$ a pair
Thank you for the info and warm welcome.Towncivilian wrote:Welcome.
HIDs are a bad idea with the stock halogen headlight housings. They will reflect a ton of glare, be difficult to aim properly to avoid blinding other drivers, and depending on the color temperature, reduce usable light output. Read here for more information. I highly advise against a HID conversion.
I believe the entire fender is different between the power antenna and fixed antenna models.
You can replace the instrument cluster, HVAC controls, and a few other lights with LEDs fairly easily. See the results of my LED conversion here. The bulb sizes for all of the bulbs should be posted somewhere in that thread; I'm not at home at the moment so I don't have much time to verify. See this thread for instructions on accessing the rear of the instrument cluster, and this article for instructions on how to access the rear of the HVAC control unit. Do you have auto or manual climate control?
The cargo shades are an item that's rather difficult to come by. They're something like $150 new, so scour eBay or wait for a member to sell theirs.
Thank you for that, I will do that now.Towncivilian wrote:I forgot to mention. Download a copy of the factory service manual, it's an invaluable resource. To save a copy of the FSM, right click -> Save As on every PDF, save them into a single folder, then use fwd.pdf to navigate. See page EL-34 for the aiming procedure.
My sincere apologies. I replied on my phone. Then saw your reply..then quoted.Towncivilian wrote:There's an edit button at the top right of your posts, please use it instead of double posting in rapid succession. I've merged your last two replies.
I remember a thread a while ago where a guy with a QX4 actually sprayed his headlights with a clearcoat. I think it had UV protectors in it or something which prolonged the clearness and resisted yellowing.Towncivilian wrote:No big deal.
Try using some Meguiar's PlastX and a lot of elbow grease to help remove some clouding on the headlights. I've had good success with that product. Perhaps apply a coat of wax to the headlight housings after clearing as much cloudiness as possible to help prolong their unclouded look.
I got the clear turn signals and in Virginia you have to have amber turn signals. Couldn't find any online, but went to my local napa and said I wanted amber bulbs for a 01 pathfinder and they pulled them right off of the shelf so I would recommend trying napa. I don't think it was more than $10.90210 wrote:MASSLE I ordered the clear ..your car was what I liked. Cost me 36$ with tax. Shipping was free. Are you using orange turn signal bulbs or just leaving it clear? Your headlights are FANTASTIC clear...wow I am jealous
