2000 pathfinder a/c belt replacement
whitcre
Car: golf, cars
how do u loosen pulley to replace a/c fanbelt on 2000 pathfinder
NISTECH
the 14mm nut in the middle of the Idler pulley needs to be loosened up not removed then the 12 or 14mm bolt from the top of the braket the pulley is on need to be loosened this will lower the idler pulley so you can remove the belt. install in the reverse order.
