2000 pathfinder 4x4 won't start after transmission install
MaxFlow
Car: 2000 pathfinder 4x4
I changed the transmission in my 2000 Nissan Pathfinder which is a 4wd. Now the engine won't start.
Any ideas?
Thanks for all the help.
My first post here so take it easy on me :)
Welcome aboard!
First off, we need to know more about it. Is it manual or automatic?
My *first* area to check would be neutral safety switch / brake switch.
When you say "won't start", does it turn over? Grind? Click repeatedly? Spin but not fire?
We'll get ya running. :)
MaxFlow
AZhitman wrote:Welcome aboard!
This is an automatic 4x4.
The engine cranks over fine but won't start.
sure thanks for any help
Let's start here: http://www.nicoclub.com/FSM/pathfinder/ ... der/sc.pdf
FIrst off, we need to check the obvious... Battery cranking power. Do you have a multimeter?
MaxFlow
yes. The car is cranking over fine. Does the security keep it from cranking over? I was thinking security possibly if it still lets the engine crank over but not start.
MaxFlow
yes. I have a multimeter and static on the battery is 12.8 volts.
