Big-Bird »
https://forums.nicoclub.com/big-bird-u44704.html
Thu Jan 17, 2008 5:03 pm
That description doesn't really give us much to go on so I have to agree with the other responses. A fuel filter will get dirty inside over time and prevent adequate fuel flow. The engine will usually sputter and then quit.
The fuel filter is located in front of the fuel tank behind a small steel splash shield. The filters are inexpensive and if you don't want to do it yourself a shop charge will run around $30-$40.00 + the filter.
The other thing that could be going is the fuel pump itself. These are located inside the fuel tank and can't be repaired. (They can only be replaced) The pump is accessed through a panel under the rear passenger seat cushion. The pump is quite expensive and they can go bad with no warning.
A computer scan would be a good idea too.
