I have a problem with a 2000 nissan xterra 3.3L. I purchased this vehicle and the check engine light came on so i checked the light and got a crank sensor and knock sensor. I drove this for a little more then it quit running so i checked it and got a crank, knock and cam sensor. I went to work and tore the enging down to replace the sensors and there was no crank sensor in there so i replaced it and had to find a new connector and wired it as to the diagram. So I replaced the crank and knock sensor, put it all back togather now it will not crank. could it have made the cam sensor bad because it was cranking the vehicle with no crank sensor?
Does any have any suggestions that might help me out??
Modified by jamesodom at 4:00 PM 6/18/2008
