2000 nissan xterra knocking
mastonhowze
Car: 200 nissan xterra
I have read many forums about the knock sensor. I have codes p0325 and p0132. However i don't get any knocking until the truck warms up. Usually about 10-15 miles down the road. Other than that it runs perfect. Any ideas? I really don't want change knock sensor.
*Edit*
I shouldn't have said knocking, it is sputtering and missing.
WDRacing
Maston,
I moved your other thread where you stated your car was missing and sputtering and edited your original post to reflect the problem. In the future if you need to add something to a post you can use the edit function or just make another post adding whatever comments you need to.
I'm not to familiar with the Xterra so I'll have to ask a couple questions. Is it supercharged? Does the octane of the fuel you use change the symptoms at all?
WD
mastonhowze
no supercharge. have not tried higher octane. had to get tow truck to take it to house. next day started and ran fine tell 20 miles. first little misfires. then gets worse until it won't run anymore. after cool down. runs great again.
WDRacing
Sounds like it's over heating to me.
