2000 nissan pathfinder no fire please help got to go to work
2000pathmaker
Car: 2000 nissan pathfinder and 2000 exterra
hi i have a 2000 nissan pathfinder 3.3 engine has 120,000 miles on it it was running good and all of a sudden it just died on me no fire to spark plugs i realy need this fixed only vehicle any help at all would be great thank yall
Dattebayo
Wrong section, but It's gonna be the main fuse in the engine bay or the battery.
Bets on the fuse.
Section list is down on the right side a bit.
ADDirishboy
Car: 2008 Nissan Titan Pro4x
Gotta be a fuse.
Dattebayo
Also, the Pathfinder has an unfortunate problem with the 4WD function sometimes...
SOme people have had the fuse blow when they engage the 4WD because of something to do with that system. It's a btich, and then probably time to ditch the car.
Just saying, it may not be your issue, but be prepared.
AZ89two4Tsx
Dead battery? lol
2000pathmaker
hi i forgot to mention my pathfinder turns over good the dealer told me the distributor is all one piece containing the ignition module.coil and it is not serviceable could a crankshaft position sensor make it get no fire thanks
Dattebayo
Well if you already knew that why did you ask us? Go replace the dizzy.
2000pathmaker
i do not know anything that is why im asking for help ive never worked on anything newer before i just know what im told i know i am getting power to the dist. but before i pay 400.00 dollars for a dist. wondering if the crank position sensor could be my problem im used to the older stuff where everything is seperate alot easier to work on this is my only vehicle ive got .trying to get running before i got to go to work thank yall for the info
Dattebayo
Sure just remember to post in the correct section next time.
2000pathmaker
what is the right post for this quistion i still need to know if it could be the crankshat sensor or not sorry for posting in wrong section but i just need some help thanks
PapaSmurf2k3
Site Admin
now its in the right section.
Is your check engine light on?
2000pathmaker
no it was not on when car shut off
2000pathmaker
ive been trying to figure this thing out now for hours if someone can help me please can a crankshaft sensor make me not get spark thanx
PapaSmurf2k3
Site Admin
so yeah, crank angle sensor could cut your spark. There is probably a check you could do to test if its good or bad... Some Pathfinder natives should be in here soon. Or you could do a NICO search to see if anything comes up for that, as well as no spark...
2000pathmaker
thank you for the info ill check back soon thanks again
