Ok, I bought one of those OBDII scanners today, and came up with the following codes:
1.) P0100: MAF Circuit Fault2.) P0160: O2 sensor Bank 2, Sensor 2
I noticed the plastic connector that connects to the MAF sensor is not locking into place and appears a bit lose, perhaps that may be the cause of the MAF circuit fault? If so, anyone know where I can get a new plastic connector for the wiring harness, because everything else is good.
As for the Oxygen Sensor, the following site lists the TSB and Nissan recommends that I replace both rear sensors in Bank 1 and Bank 2. I'm assuming that this was my original problem.
http://www.nissanhelp.com/Owne...1.htm
