2000 MaxSE stalling when not pushing gas
bradfordrb
Brief preface - my car is a 2000 Maxima SE w/ ~80k miles; I've replaced one of the 02 sensors (believe it was the second (rear) bank pre-cat) and changed out one of the ignition coils (#2) and all six spark plugs around 6 months ago.
Recently the car has begun to stall when I'm not pressing the accelerator - first noticed it when shifting to park after pulling into the garage, car died before I got to the keys. Since then it has repeated stalling SEVERAL times, usually in park or neutral. Car runs fine when driving and I can't hear/feel any symptoms of misfires. For example, I was driving around town and began a downhill.. wanted to see if it would stall with me taking my foot off the gas, rpms dropped but then recovered; so I shifted to neutral - almost immediately the rpms dropped and the engine stalled. The car has always cranked back up right after stalling (sometimes it stalls a second time but then cranks up).
Any help would be appreciated! I have not checked/changed the fuel filter/fuel pressure yet.
Thanks in advance,
NISTECH
since the car runs fine while in gear and does not stall I dont think its a fuel or spark problem but an idle air problem. Either to do with MAF input or IAC motor. try checking for codes, post your findings.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1997 Maxima 5spd Supercharged
1995 240SX S14.5
1995 240SX S14
1994 Hardbody KC V6 5spd 4WD
1972 BMW 2002
1972 BMW E9
check your MAF sensoryou might want to try cleaning the MAF and seeing if it makes a difference, make sure whatever you use is sensor safe, the MAF is pretty sensitive, maybe someone else can recommend using something, electrical parts cleaner maybe?
also what about vacuum leaks? check all your hoses, does the car idle in gear fine? My Lexus would idle a bit jumpy, but would drive fine, and then it would stall when I shifted it into neutral or park, there was a tear in one of my vacuum lines
:D
bradfordrb
Thanks for the help guys, it was raining here today so the Autozone guys wouldn't take their OBDII readers outside. The check engine light wasn't on earlier; I managed to get it to turn on after I disconnected the MAF on my way to cleaning the throttle body butterfly valve area. The car seemed to idle ok w/o the hoses hooked up but the moment I closed the gap between the flexible air duct between the resonator box and the valve the car stalled - maybe it was coincidence.
Anyway, now the SES light is on and I'll try to have them pull the MAF code and reset it tomorrow. Should I expect other codes to be thrown from earlier even though the SES light wasn't on?
bradfordrb
only code thrown was P0100 = MAF; I suspect I made it throw this one when I cranked the car after unplugging the MAF :) Autozone reset the computer and it is still stalling.
I've attempted to listen and check for vacuum leaks, but haven't heard anything yet.
Since the car will run fine occasionally, I've begun to "try" to make it stall to see if that might help diagnosis. In neutral:I've found that if the car is running around 1000 rpm and I rev it up to ~3000 then let me foot off the gas, the engine almost always stalls. If I rev it up to 3000, then slowly drop it back to 1000 and let off the gas, it won't stall immediately, but may stall after a minute or two without throttle. While driving:Hard acceleration followed by a shift to neutral = stallGentle stop with no accelerator & rpms ~ 900 followed by shift to neutral/park = no immediate stall, but may stall after a minute or two.
NISTECH
with it idling try wiggling the harness coming off the right strut tower going to the engine,see if wiggling/twisting that kills the engine. If it does you probably have a broken wire in that harness loom. TSB exists for that, but several codes are usually associated with that failure.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
I would try cleaning the MAF with electrical parts cleaner, my friend with a 2000 max had the same exact problem, and he couldnt figure it out... MAF does get pretty dirty
its simple and you might as well just try it
and for vacuum leaks use a vacuum gauge to see if the vacuum jumps around, probably you would have a leak
bradfordrb
Well, after checking the wiring harness and vacuum hoses I decided to get the MAF changed. New MAF = problem solved! Thanks to NISTECH for his guidance.
carnal_c30
Car: 2001 QX4 4WD
2002 QX4 4WD
1999 Q45 VIP life
1996 I30 5spd
1998 I30 Auto
1995 240SX S14.5
1995 240SX S14
1972 BMW 2002
1972 BMW E9
I hope you tried to clean the old MAF first, its a bit pricey, kind of alot to spend, 2000 Maxima MAFs are pretty hardy, only Maxima MAFs I've heard of having more than miniscule problems have been the 2002 MAFs...
oh well glad you have your problem fixed, still have your old one?
bradfordrb wrote:Well, after checking the wiring harness and vacuum hoses I decided to get the MAF changed. New MAF = problem solved! Thanks to NISTECH for his guidance.
bradfordrb
Well, I didn't really know what all to check on the old one.. I pulled it, checked electrical connections to the sensor and sprayed some computer motherboard cleaner on around the inside.. not sure if that did any good or killed it; but the car still stalled after reassembly. I was able to get a new MAF for ~$100 after tax etc.. but threw the old one in the trash (left the house yesterday :(..
